Hi everyone,
I've been having some trouble with my Logitech Z-5500's and I was hoping I could get some advice from you knowledgeable folks!
I noticed a low buzzing sound coming from the subwoofer box and it turned out to be coming from the toroidal transformer. (I originally thought it was coming from the sub itself because of magnetic interference from the transformer but it's coming from the actual transformer.) The hum starts when the switch in the back of the sub is turned on even when there is nothing other than the power cord plugged into the system. It seems like whenever the transformer is powered it makes noise.
The brand name on the transformer is TENPAO and the model number is TOU543005F0.
I was wondering if someone has an idea of what is causing the hum or a suggestion for what could be done to stop the transformer from humming?
Thank you!
Thank you!
Mount it to a rubber block, fill it with silicone, or hot glue. It's probably not bad. Just noisy.
