LM7812 and LM7912 broken? How to check
How can I test these on the board circuit.
Its is a receiver Denon avr 1311 and the red light is blinking.
I reset the board for many times but its is death
I cannot see any strange problem on the different circuits
I read the most problems here are the regulators 12V.
I measure with the multimeter (black middle leg and red rightleft leg.
I get some numbers like +0.4 or -0.4 or counting back from xxx until zero
What do I have to read here normal and what is the right way to measure
I measure with the multi meter with V dc on 20V
Thanks,
Frits
If the regulator is Ok and the circuit after isn't shorting / loading it, the output pins should measure their nominal regulated voltage when referenced to ground . Accept minor tolerance say +-100mV. Please note that the input pins should have a higher Voltage (min 2-3V higher) in order for the regulator to work and a minimum load also. A Led as a load (20mA) usually is enough. I would check the diode bridge and the capacitors before and after the regulators. Measure the voltage on the capacitors after the regulators.
Thanks,
yes you are right
I found two burnt diodes on the PS and replaced them and also the 7812+7912 but there must be more problems because it stays yet into the death modus. I have to do more rescue work on it but it is difficult to find.
