Look into replacing resistors with something like MCP4012.
If you want voltage control, don't use a 555, use a CD4046/74HC4046, a better chip for a variable oscillator, anyway. Use 555 only if you need to vary duty cycle. For most audio uses you'll want 50% duty cycle and something like the 4046 is more appropriate and has more versatile control.
