AndrewT said:With 6k8 I would use a good 10uF electro//2.2uF metallised film. Both are cheap and fairly small. These will give F-3db @ <2Hz.
If you could afford a Solen polypropylene it wouldn't be too large or expensive. A 12uF 400v type is 1.14 x 1.5 (29x38) and costs $5.10.
In any case that input cap is where you should put your money in.
Hi Dxvideo,
Your idea of using an LT1210 is flawed. The LT1210 is a very fast current feedback power op amp. It is capable of 1.1 amperes output. I am pretty sure you would need a different layout with much more care in decoupling.
As for your power amp, install a buffer on the input to raise the input impedance and include a DC blocking cap. This would be much safer and it might even sound better.
-Chris
-Chris
Hi Dxv,
for low bass passing through the power amp with least attenuation and phase change go for a big DC blocking cap on the input. With 6k8 I would use a good 10uF electro//2.2uF metallised film. Both are cheap and fairly small. These will give F-3db @ <2Hz.
I have four of 10uF 63v MKT type caps. I've used 4u7 MKT type for another project and happy with them. So I can use 10uFs for amplifier input with 100n parallelled...,
What are the resistors & caps at the amp input?
This is my circuit;
http://www.diyaudio.com/forums/showthread.php?s=&postid=1301290#post1301290
Any canditate for that posisiton?
Thx ...
Not much difference, but some simplified. Is that any good?
And a PCB design for all;
PS: Component codes not related to circuit schematics.
Hi Dxvideo,
-Chris
Well, any higher current voltage feedback op amp would work well. The NJM4556 is specifically designed for driving headphones. It would be a wise choice. If you want one, all most all Japanese CD players use one. Pull one out of a scrap unit.Any canditate for that posisiton?
-Chris
