hi all.
i made this amp:
it work but have very low power.
and + rail mosfet get warmer.
i need your helps to solve these problems and power up it to 400w/4R.
i made this amp:
is this sch better than upper sch?
i don't like to use irs2092 because i can't find original ic.2092 expensive.
i just like to make class d amp with 494 or 3525 or with op amp.
i tested 494 but mosfets get warmer about 50 60 degree.
if anyone have tested sch of class d amp with tl494 or sg3525,ir2153 or etc plaese send here to use or send here refrence address
I don't suppose you've ever looked up the original UCD whitepaper, have you?
https://assets.nexperia.com/documents/user-manual/UM10155.pdf
i didn't see. i don't need hifi quality because i use it for subwoofer.
and UCD 's board a little big. I have space restrictions
IC occupies less space.
What do you think of the circuits I've posted?
I love this schematic how is it:
As i don't get good result from TL494 ic for class d,I don't know about it works.
but someone has tested it and get good result.
see here:
DIY Good Class D amplifier
see here:
İ have idea.
i can use a class d amp that have square wave on output(like the TPA series)
Then boost the output with external mosfet.
this have beter result but there is a little problem. i can't find tpa ics
it just on kits.
it just on kits.
"Boost the output"? Not gonna happen.
Why not just go for one of the many IRS2092-based amps out there?
You're not trying hard enough then 😉 Mouser carries them, and so do Farnell and Digikey.
Ready-made amps seem to start for around 20$ on eBay. If that's still expensive, then i don't know what else to tell you 😕
Those cheapest eBay amps are from China ("obviously"). Maybe searching for something on the local market (if at all possible) might be... better? I dunno...
that's true but i can't order from china or USA now .
i must use 494 or 3525 or etc for this project.
why U don't like 494 circuit?
- Class D
- LM393 Detex audio class D amp
