lm3886tf layout pcb
here is a ultra Quiet lm3886tf board that works fine.
all resistors are 1/2 watt .caps are 63 volt . 220 pf is axial standing on end poly cap. the 2watt flameproof 10 ohm 1% is wound with 10 turns of magnet wire 12.2 mm or 22 ga. the mute connects to -v and mute by the input with a single throw toggle switch
