Gentlemen,
Curious to know if someone has tried LM3886 in an amplifier with output in Class-G topology??
If so, can someone share the schematic ?
Regards,
Regards,
In this thread, someone discussed the same:
G-class with LM3886
It seems like this is the wrong chip to use for Class H/G (whatever the difference is.) The chip is made for Class AB designs and is most efficient in that config. You cannot actually make it a class G (H?) amp because this is an integrated amplifier chip.
G-class with LM3886
Its not about making Class G only with LM3886 chips but utilizing LM3886 as Inner Power device and additional Output/Mosfet as outer power device.
Output Current Limit 7A (tipical 11,5A ) LM3886 datasheet(3/20 Pages) NSC | Overture TM Audio Power Amplifier Series High-Performance 68W Audio Power Amplifier w/Mute
Cannot be exceeded by the top stage. You will have to use a high load resistance of 16 ohms or more. There will be no gain in power output.
It will take a parallel connection of several IMS to obtain the required current.
Correct. 3886 cannot be used, but TDA7294 can. Because the output stage is NOT directly connected internally on the ST part and can be separately powered by the class G switching circuit. If TI were to *make* a 3886 with the collectors of the output stage separately pinned out, you could do something like this. As fas as I know, no such animal exists yet.
I can only imagine variable voltage supply to the entire 3886 will just cause immense crossover distortion as the auto adjustment circuitry tries its damn hardest to keep up.
- LM3886's Output with Class-G Output topology ??
