I'm planning to build LM3886 based amplifier and got couple of question.
I'm planning to use Feuerbacher Copper Amp scheme because it is so simple. In that scheme PSU is 18-0-18 doubled mono. I would like to use single 30-0-30 260VA toroid, because I have one. Is this possible? Planning to use MUR860 scheme as shown in copper amp site. If using 30-0-30 does copper amp scheme need any value changes of components?
Also wondering what Cs means when it says 2200uf electrolytic; || 100nF polypropylene. What this "||" means?
Info about copper amp -> Mick Feuerbacher Audio Projects
... because it is so simple.
In Germany we have a saying: if it costs nothing, it's worth nothing.
Depends on the load impedance. With 4 Ohm speakers use 18-0-18. With 8 Ohm you can go higher. 30-0-30 is definitely pushing it. Although as long as you only use 2200 µF of smoothing capacity the voltage will sag sufficiently under load that it might even work.
Heh, maybe true, but I think it's ears that tell, not the costs. That's why I like to try something simple like gainclone. I built one amp using 2SK1058 and 2SJ162 pair. That's where I have 30-0-30 260VA toroid left. I would like to use it because toroids are the most expensive part of the project and after building a new amp witout it I don't see any usage for that 30-0-30 toroid.
Is there any recommendations what should I try then? I want it to be enough simple. I listen mostly CD's and I'm thinking that if amp has volume pot, there is no need for a preamp. I think volume pot is like passive preamp (?).
Oh dear another chipamp implementation that is likely to smoke and kill speakers of unsuspecting beginners. Please don't build this.
Hmm, I think I'm going for the briangt's Non-inverted LM3886. It looks pretty and simple. And I have read at least something good about it. Because UK is far a way to order premade pcb's I'm thinking of building them my shelf. If I use same kind of component assembly as in those pcb's is there any major copperlines which cant be next to each other, or have to kept short. Ground is usually as "big/wide/long" (don't know the word) as possible. Am I right?
Hi all
I built a LM3886 amplifier last year using the toroid from a nad 320bee
The dc psu rails with the amp at idle where approx 42 volts.
I took it easy for the first week but after that gave it some stick
and to my surprise no smoke. i have now removed some of the windings from the transformer and the dc rails are now approx 24 volts at idle.
The amplifier now sounds so much better as i found it souded very glassy with higer supply volts.
I also tried a few other ei transformers and notice they make a big diffrence to sound.
Also i noticed that too much capacitance on the res caps dont help the sound either.
im now running 2000 uf junkbox caps the amp now sounds faster less harsh very nice
Ian
Ian
The cost of shipping a few PCBs from anywhere to anywhere else is almost zero, so I don't really see the problem. However, if you really want to make your own PCBs, pay close attention to the grounding scheme to avoid instabilities. Searching diyaudio for threads related to chipamp grounding would be a good start. Using a star ground with separate return paths to the star point for PSU bypass return, feedback loop return, and Zobel return (if used) seems to be the consensus solution. Or, if you really want to go guerilla, why not hardwire the thing with no PCB at all? Again, you will find many examples by searching diyaudio.
you Germans should really come to my country, where genuine and fake items are nearly impossible to notice from their costs nor their appearances.
so if it costs you a headache, then it worths a headache :lol
what i'm trying to say is,
the original GainCard was made based on simplicity.
the zen approach of Kimura's San was proved legend by the failure of ourselves to build the clone of GainCard so we just called it "chip-amps" today
so think to it again;
"maybe only the simplest can accommodate the most complex"
(as quoted from 47 laboratory page)
Is the transformer 220:30+30Vac , or 230:30+30Vac, or 240:30+30Vac?
What is the regulation of the transformer?
What is the maximum voltage from your supplier?
That one diyer may have used a 4% regulation 240:30+30Vac transformer on a 220Vac mains supply with a 5% voltage tolerance.
The specification says that 84Vdc is the maximum when a signal is present.
and 92Vdc is the maximum when no signal is presented.
Is this what your looking for? Trafox - Maailmanluokan laatua. Suomalaisella asenteella - Toroidal transformers I didn't find better information with the word regulation.
In our appartment lights don't dim when refrigerator turns on, so there is enough voltage I think. Don't know if it matters, but there are two big nuclear plants 30km from us. I guess that our voltage is pretty stable 230V.
- Chip Amps
- LM3886 questions
