LM3886 PSU , need
Thanks 4 info about good diodes.
But I'm still wondering about..........
Can I use a bit modificated Carlosfm PSU to support 2X PBA-150 board??
Can I feed both of the BPA-150 from the same PSU or beter use two PSU's (1 for the "normal" and one for the "inverted" signal) ?????
and one more....
I made Alexw88's desighn. with the Lundahl input transormers. The cener-tap is connected to each board... so ....., if I need to use 2 PSU's, and I connect both "signal ground" from the L1545A.... doesn't it couses some ground-loop??? (and don't forget I feed 2-2 boards from 1 psu at this moment)
Yes, if you take the necessary steps for the higher power demands.
Yes, you can.
That is the trick. You have to design it so that ground-loops are avoided. There are great threads on grounding techniques in the forum.
