LM3886 Power supply 24 0 24
24VAC gives more then 30 VDC
My last transformer with 2x24VAC had about 35VDC with a light load,
so I´d guess it´s between 30-35VDC assuming nominal AC voltage from the wall.
Look at page 14 in the LM3886 datasheet.
With 6Ohms and 70V (+-35V) supply voltage you are right at the edge with Pd of 40W.
Assuming that the DC voltage will sag a bit under load and only +-10% varying AC-voltage, I´d say you´ll be fine with that transformer.
You will need a proper heatsink though if you push the amp hard.
Guidelines also on the same page of the datasheet.
