LM3886 optimisation and power supply review
two caps or four caps?
Each Cs is an electrolytic and a ceramic.
A Cs attached to +ve and -ve supply pins = four caps.
More clearly...
The diagram of the amplifier in post #1 is for one channel and has two Cs (one for V+ and one for V-). Each Cs has a 0.1uF, 10uF and 1000uF near each LM3886.
In the second diagram in post #1 and post #38 (thanks for protection improvement), the PSU I'm using most of the time for testing has two 4700uF in parallel with a 1uF for V+ and the same for V-.
I’ve modified the case, the same internal circuit, now with a much bigger heatsink. We’ll wait for the summer to see the difference (hot room around 30 C).
43°C at the heatsink, or at the exposed tab, or for Tc.
Ts=43°C is hot, by my reckoning, because that gives Tc~50°C
If ambient rises, then Tc approaching 60°C becomes possible.
That would be way over the Tc=25°C that National use to show the 3886 performance.
