LM3886 kit from AM
C3, the mute, is tapped into the Signal Ground.
That might create unwanted noise.
The Main Audio Ground, or Star ground as many refer to it, is the underside of the Power Ground input terminal. That is where the Power Ground meets the Signal Ground and the Speaker Return and the MF decoupling Return.
There is no RF filter. Add it on.
If you use two Boards in a stereo chassis you will need to add a resistor+2diodes in the Signal Ground link. There is plenty of room on the top side between the two sets of 2pole terminals. drill 6 holes through for the 3 components and solder to the ground that runs along the front edge. Then cut the trace between the components leads.
There is a large loop area in the signal routing. I can't see what you can do to reduce that.
There is no HF decoupling. Add this directly to the Power pins and take a short Ground link to the MF decoupling Ground.
When you run two or more amplifiers inside one chassis there is a ground loop as soon as you connect the second interconnect.
To reduce the current in that external loop you must increase the resistance between the Signal Ground and the Power ground so that the voltage drop along the signal return wire is reduced sufficiently.
thus for stereo you need two sets of:
1n4002 in one direction
in parallel another 1N4002 but facing in the opposite direction (these make up an inverse parallel pair).
and a 10r low power resistor in parallel to the diodes.
Fit one set to each PCB.
Some refer to this as a "lifted ground". Learn to stop using that phrase. "lifted ground" can mean very different topologies to different builders, one of which is potentially FATAL.
C7=33nF sounds very wrong.
If it is needed and that is a BIG "if" then try 5pF in small steps to 47pF
R5 ~ R3
input RC is a low pass filter to attenuate RF interference.
You already have R6. Add C in parallel across R5. Try 1k and 470pF
C4 will need to be an electrolytic. Some say polarised, other say non polarised (Cordell),
Make the RC of R4*C4 big enough to NOT work as a LF frequency filter.
C1 & C2 are dual capacitors. See National datasheet. Cx or Cz?
Thank's Andrew, I'll drop this for now, and see after at sounding..
For network with 2 diode and resistor at ground input, I have the diodes but only 121 Ohm for resistor, not 10 Ohm..
It's work, or it's better with 10 Ohm.
Phil.
did you read this?
