Greetings, I am repairing a powered speaker that has an tda7294 driving the compression driver and a TDA8954 on the low freq driver. They are fed from a common supply of app +-32v. The 7294 however has an offset of app 0.45v on the output which drops to few mv when an 8 ohm dummy load is connected when the dummy load is removed it goes back up to 0.45v again. I used a scope to check for oscillation. Is the chip faulty?
