im sure some one has talked about it but i cant find it witch one is better isolated or non im about to order samples.
thanks.........🙂
thanks.........🙂
Although I've been using non-isolated version mostly, my recent experiments indicate that isolated version sounds smoother and less harsh. I would recommend isolated version and that's what I'm using from now.
tiroth said:You are also saving yourself a world of mounting concerns with the isolated. 😉
on the other hand, you need a much larger heat sink with the insulated version
i got a few to play around with so we shall see. there samples so
if i loose one o well. the heatzincs on my case are from a 200watt
amp so it should keep it cool🙂
Peter Daniel said:The heatsinks on your amp are good for 6 channel surround amp.
this is true
next one will be smaller
Peter Daniel said:I wouldn't think so. The chip transfers less heat to the heatsing, when it's insulated😉
that's not the way the thermodynamics work, the R(t) of the insulation is a barrier has to be added in -- I worked this chart up which illustrates NSM's recommended oC/W ratings (left Y-axis) at various rail voltages (X-axis), P(out) and P(d) are illustrated on the right Y-axis. A lower oC/W is a larger heat sink, in every case the increase is 1 unit of oC/W.
- Chip Amps
- lm3875t? or lm3875tf
