LM3875s & low impedance loads - your thoughts?
All,
I have seen on here that some think that the LM3875 is not really suited to driving 4 ohm loads....
I'm wondering what other people's experience of this is, and would be interested to hear what other's think.
-- Especially Peter D..... He is selling a product based on this chip (I think), does he recommend his amp to only be used with 8 ohnm speakers, or does it work Ok in his experience?
Up until recently, I thought my speakers Acoustic Energy AE120 were 8 ohm - the Manufacturer's info states they are 8 - but I read a review of them that said that they are 4 ohm! I haven't done any extensive tests, but a multimeter across the terminals looks more like 4 ohms to me.
So, in my experience, using these speakers and my Premium Brian GT kit, my system sounds very good (to me anyway!) Is it because I stayed with a lower voltage toroid (300 VA dual 18v secondaries)???
Let me know what you think...
SteveM
The lm3875 is four ohm stable, you can take a look at National's spec sheet which shows the voltages vs load. Yes, because you're using 18v secondaries, you can drive a 4 ohm load better than if you had higher voltages. But drawback is that with 18v, if you drive higher loads (6, 8 etc) then you have less wattage potential.
This is just theory from what I've read, but I'm currently hunting for a 22v transformer which I think is the best tradeoff if I want to use between 4 and 8 ohms.
The problem is really when you have a 4 ohm low efficiency speaker, because then you will have to go higher in voltage and get into the clipping area of the chip.
In such cases you would need to parallel two chips to drive it. But using the Overture Design Guide shows that with a +/-30v supply you shouldn't have any trouble for a 4 ohm load with the 3875. Power should be close to 80 watts.
Be sure to use a 250/300VA transformer though.
First of all I should trust the manufacturer spec, particularly if it's a serious one like AE. If they say it's 8 ohm it should be. Maybe there's some dip in the low frequencies, but most speakers do, particularly if they a bass duct. The static resistance is not really that meanigful. The NHT 1259 I have is an 8ohm type and also reads 4 ohm.
What's the efficiency AE says it is? That data might be important in the review.
Think this: the AE was designed for the British market, which usually prefers low wattage amps and small speakers. Such combination has to be efficient, though usually less efficient speakers sound better. 30 watts should move the AE a lot, so with 80 watts you should be covered.
Carlos
officeboy said:
Well I don't know what happens when you hit the internal current limit, I would suspect clipping. But an 18Vac supply is right where you stay under that 5A limit at 4ohms.
At 22V, you have not only reached the currunt limit, but it's to hot for the TF package also. :hot:
The graph shows that the chip peaks at 28v input before dropping. Does this drop signify clipping, or the inbuilt protection or what?
So 22v secondaries after rectification is 31.1v, which is too much according to the chart. (BTW, what voltage loss is there through the rectification process, or does the x 1.414 account for this?)
18v comes to 25.45v, and looks like a sensible voltage to get good wattage out of the chip and remain under clipping (according the graph).
I don't think there is anything wrong with driving a 4 ohm load with an LM3875 at 30+ volts as long as you keep the input level low enough so that it does not try to drive the amp beyond its current/thermal capabilities. The graph does not mean that the amp will always clip when driving a 4 ohm load with a Voltage > 28 volts. What it is saying is that the chip can not put out more than 55 watts of continuos power into a 4 ohm load. This is a function of the chips ability to dispipate heat long term. There could, in fact, be advantages to to using a higher voltage with 4 ohms. While you still can't put out more than 55 watts continuous it will allow for much higher short term pulses.
Just a few thoughts on my experience using GC's with 4 ohm loads. I have tried the following Avel transformers with a three way active speaker system. The amplifiers were built as monoblocks - so one transformer was powering one channel.
18V - 160VA
22V - 160VA
25V - 250VA
In each case the higher supply voltage gave less usable low end out of the GC's - and produced substantially higher operating temperatures. I even tried 10,00uf caps on each rail of the 22 and 25V supplies and they still clipped before the reference 18V system.
The woofer section presented it's lowest impedence of about 3.2 ohms at 130Hz. If as some have said the 3875 limits at around 5 amps then my max voltage swing is around V=IR or about 16volts.
I assume this is rms current which would put my expected voltage max at about 22.6 volts peak. I don't have a storage scope but on my old HP unit I observed signals clip in the 22 to 25V peak range with the 22V trans and no 10Kuf caps.
I'm going back and try the 10,000uf caps with an 18V/250VA transformer and will let you know what I find.(Couple of weeks before I can get to it)
Just one other thought - the heat dissipation was enough that the 18V ref. unit had no heatsinking other than the case, while the 22/25V units had heatsinks and still got much hotter.
Thanks for your replies people, keep it coming !!
Without doing some further tests, I can't really be sure of the impedance of my speakers now! I'm tending to believe the manufacturer's claim that they are 8 ohm.... the sensitivity is claimed to be 89dB @ 1W.
Now, I don't tend to play music REALLY loud these days, but I had to test the amp, didn't I??
It looks as if I'm unlikely to go into clipping with this setup - I found some music that I like, with a strong output, and turned the volume up, and up, and up. I actually had it running at full power for a short while. That kind of level is way beyond "comfortable" listening levels, but still there was no sign of clipping or distortion. Obviously, things weren't as smooth at that level, but hey, I didn't expect them to be...
I did sort of expect the bass to run out of puff, seeing as there's only 1500uF per channel of capacitance to help it along..... still wrong ! (it is possible that the caps on the other (unused) channels of this 6 channel amp were helping out though..)...
Yeah Carlmart, these spkrs have 3 reflex ports each. I bought them back when I was living in England, and used to drive them with a 35 watt amp (AMC 3025a), which also produced enough volume for my tastes. BTW, I am using 2 x 300 VA 18v toroids. When playing in simple two channel stereo, each channel has a 300VA transformer to itself....so no current problem there !
SteveM
18v + 18v will not provide you quite a high power, even if you use 1000VA transformers, be aware of that. So I am glad you did lisening tests and found not audible clipping, as you should if they clipped. It means efficiency is fine.
On the tests I did, using 3886s which are more efficient, the 18+18 amp clipped before than another using 30+30 in 8ohm speakers that only diped to 6 ohm. The former clipped at higher levels, probably because speakers were not too efficient.
Carlos
Just because you couldn't make the amp to clip, it doesn't mean it's driving those speakers properly.
You have low voltage, so the chip works at a lower temperature and with a good heatsink it may not have problems with 4 ohm loads.
The LM3886 is much better for that, it has double the current.
It's what I use.
To check if your amp is driving the speakers properly you have to put some extremely dynamic music, with strong bass impact.
If you know that recording well, heard it in several places, you can compare.
I have some CDs with extreme bass that defeat many systems, really.
But I know the bass HAS to be tight, and it is, with my (regulated) GC.
Bad bass always muckles the rest.
Some times the effect is not so obvious, but is there.
No soft music for testing.:D
Note: B&W is a good example: 602 S3 has 8 ohms, 91db (says the manufacturer).
But curiously (you may think), you need a serious amp to drive them, or you may think they're crap, bass is not tight.
I don't like them at all, anyway.
It happens that they have impedance dips to as low as 2.8 ohms.:eek: :bawling:
EDIT: You need a good source to test of course, or else don't loose your time.:rolleyes:
After comparing my GC (LM3875, 2000uF at chip, 18V 250VA per channel) with a Denon 1800 AV amp driving my 4ohms speaker,
I found that my GC has a deeper bass, much better mid and highs and more details.
However, the Denon can produce a much tighter bass than my GC, even at low listening volume.
Why would that be? Since I am listen at low volume, the 3875 should not be limited by current....
Would changing to 3886 help in this case? Or should I go for a regulated supply?
Alex :confused:
carlosfm said:
Yes, you should go for both (LM3886 + regulated PSU).
Your GC is not driving your speakers properly.
LM3886 + regulated PSU will sort that out, you can't imagine the difference, it will take you to Krell territory.:D
Ok, then I guess I have to build a new GC.... BTW, carlosfm could you post your schematic of your GC and regulated PSU? I have no experience with regulated PSU.
Peter Daniel said:
It may depend on your PS caps. What are they?
I have 120uF at PS, is that ok?
Thanks! :)
Alex
Well I'm far from authoritive on this matter, but you may want to consider that most people use 1000uf upward. And this is still regarded as small but good I believe. Also, since larger caps will be better for bass (as I undertsand it for some designs) then 120uf seems exceptionally small in comparisson.
Retired diyAudio Moderator
Joined 2002
I am using my LM3875 gainclone (2x24vac transformer) on my 4 ohm speakers, and it is fine for me. (speakers = Seas Thor TL)
I don't get any clipping at high volumes, and it can go louder than I can tolerate for more than a short time. The bass sounds quite good to me also. It seemed deeper after I swapped to the Black Gate 1000uF capacitors.
Brian
Vikash,
I have 120uF on the PS, but I also have 2000uF at the Chip, is that ok?
BrianGT,
I think my GC sounds very good, when I listen to Jass and POP music. When I listen to drum music CD, I started to notice that while the bass is deep, it is not tight.
The bass is ok for most of the music, but when a lot of big drums are playing together, the sound seems to smeared together. On the Denon I can tell each individual drum strike clearly.
Big Drums :
Guys, each epeaker is a speaker and it's not just that it's 4 or 8 ohms average declared impedance.
My Epos 11 speakers are 8 ohms but very difficult to drive, they need power.
What I thought that was some room resonances with CDs with extreme bass completely vanished with my regulated GC.
And my unregulated GC has LM3886 chips too, 2x24v 384VA toroid and 1000uf caps per rail.
You have to spend money on a good amp (if you buy a commercial product) to drive this speakers properly, and if you do, they reward you with an impressive performance.
That's what I have now, with regulated PSU+LM3886.
:angel:
