Hi
I need help with an interesting question, I am currently examining a AM 1Kw transmitter which currently uses
6 amp fuses for fault /DC protection- 1 per module.
I am assessing whether just fuses are the best answer
for this output stage. I think two LM338 devices acting
as a current regulators will provide another layer of
protection.
Also to consider is that AM modulation is switch mode added at a sine -wave frequency of 125Khz across the DC rail ( where the fuses are ) into a bridge 4 device per module Fet network
Will a LM338 arranged as a current regulator Vref/R
allow this modulation frequency to pass as well. ? or
does a LM338 attempt to block frequency content
preferring to live in a DC environment.
Has anyone had experience with frequency and LM338
LM317 family of devices ?
My other option is to design current regulation within
a DC part of the board before modulation is added.
Thank You 🙂
protection.
Thank You 🙂
A few additional points:
The idea is to current limit the circuit to approx 5 amps per module - which should be within the 338's capability
rather than just relying on 6amp fuses.
The fuses will remain to protect the circuitry in case of outright abuse.
125kHz is well beyond the knee in the frequency response of the regulator. It does not work very well at this high a frequency.
That may lead to some serious performance shortfall.
Hi Andrew
Thanks very much, it begs the question what is the
frequency response of a fast blow fuse ?
I can design this limiting earlier which should solve
the reliability issues. Many Thanks
Cheers / Chris
Cheers / Chris
