HI guys, I created an amplifier using lm1875 chip using the scheme in attached files. When I used the pc jack as an input there was a little bit of noise but nothing terrible. But recently I bought a sound interface "Komplete audio 2" and when I plugged it in, my speakers make terribly loud white noise. i think it could be a high gain issue but i'm not sure so can you please help me.
PC is inherently a noiser environment. Check anorher source: a phone, a radio, a portable CD, etc to discriminate where the problem is. It may be supersonic oscillating or simply amplfying noise.
The noise is there only when I use the sound interfacePC is inherently a noiser environment. Check anorher source: a phone, a radio, a portable CD, etc to discriminate where the problem is. It may be supersonic oscillating or simply amplfying noise.
I think you can try thisWelll then, the solution is Obvious: Don't use the Noisy interface contraption.
your amp as sym input, do you use the line out of the interface ( backside) ? Not the headphone one ?The noise is there only when I use the sound interface
Do you have a way to confirm that the interface is not the cause of the issue ?
Yes i was using the backsideyour amp as sym input, do you use the line out of the interface ( backside) ? Not the headphone one ?
- Chip Amps
- lm1875 white noise problem
