May this can help you: Laplace expression for small-signal can be used to investigate feedback and stability of the LM1875.
The expression that I use in a Laplace block in SIMetrix (evaluation version is sufficient) is:
73000000/(s+2500)/(1e-7*s+1)/(2e-8*s+1)
This is of course a very rough simplification. The Boucherot compensation for inductive output compensation can NOT be investigated with this simple model.
FS
FS
