LM1875 hum, strange problems.
0.3V is not zero. It's actually really high for a source. Add that your 100uF capacitor to ground on your feedback is quite a high value (it affects low frequency less, which also makes it slower to respond to DC), it could be exactly as I said. If a capacitor before the pot fixes the problem, then try removing the capacitor after the pot.
What value is your pot?
I will try that.
Yes 0.3v is high...
Pot for now is 100K, when get one i will put 10K. Because i copying LM4780 combination with 47K biasing resistor and 10K pot.
100uF feedback capacitor is made on porpose. Input cap -3db is if i remember correctly 1.5 Hz, so i had to make feedback even lower, it is 0.7Hz.
This gives amazing low frequency sound 😀
