Hi all
When I switch off the ampli the woofer of the speaker oscillate badly for few seconds.this happen only on one channel. .
when we remove the couplage cap between driver and output stage in fact we remove the feed back .
this problem happen only in one channel .....so how e can find solution in circuit changing ?
sorry just carefully i looked at schematic !!!!! the 100 mfd in feed back !!!!hi all
Just to thank all that try to help
This afternoon I check all component and they were all good
Reducing the feedback did solve the problem
Remain still strange to me why only on one channel
Anyway thanks again
There is no capito in the nfb network.
And May i should have one. Probably with a correct site capacitor There this oscillation would not occour
Problem is to find the right value require a lot of test and i have no time right now as going to work. Project for winter time
Thank you
Thank you
- Tubes / Valves
- Little help for beginner?
