Hi everyone, I think this is my first post, not sure cause I frequent so many forums . Anyway I have a question regarding the little gem mk11practice amp from runoffgrove.com, I drew the circuit up in Eagle and then I lay the parts out as per the Pdf pcb layout that was supplied and the two don't seem to add up unless I swap the connections and grounding between terminals 2 and 3 on the 2 lm386 op amps.
Which is correct? the layout or the schismatic? I I ask because it seems a few people that have built this amp have had some problems, hence the reason I compared the two.
Thanks for any input.
regards to all,
Walt
regards to all,
Walt
