hi all
just want to report this driver, a 3.5" sanyo 8 ohm 8 watts, R-S6879
when you come accross this driver, do not pass it, it sounds wonderfull
i was amazed how much music comes out of this little thingy
i just experimented with a small closed box and later with an open baffle and the midrange was so wonderfull and life like, that i ended up using it instead peerless driver for ht project
this driver is definitely designed as full range, it has quite an extended hights /although I ended up using a tweeter with it/
its bass is not deep, but it's there and in a small closed box actualy sounded pretty balanced
that's all
that's all
Hi adason,
Nice drivers. I wonder if planet10 knows about these? He's a real soundhound for drivers like that.
Cal
Cal
The dustcap on yours is different than the ones i just sold (but they should ideally get removed anyway). Yours is the 2nd i've ever seen.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5821269498
dave
dave
Hi Cal,
well, you are right, obviously he does.
Those are the exact drivers, except the slight variation on the dust cap.
The reason I am reporting theese is the sound. Fabulous. Just look at the size of the magnet. If I were not lazy, I would put them in some suitable enclosure like Voight pipe or blh, i am sure they would perform well. But i am. Plus i have way too many other small full range drivers sitting around.
Thanks, planet10, for the link. Did you by any chance measure efficiency or frequency response?
ed
ed
adason said:Did you by any chance measure efficiency or frequency response?
FR no, but impedance curve & T/S numbers are in the auction. Don't take them as gospel for yours. On versions of the 103As that i've measured lots of, the parameters can vary quite a bit.
All of the FE103A variations sound excellent, The holey basket Corals are generally considered best of breed. And they all get even better tweaked up. To better a set of tweaked ones with new drivers you have to expend over $150.
There is an extensive thread where i catalogged a whole whack of the variations. If we can find it, we'll have to add these ones in.
dave
This may be the thread you are talking about:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=56478
scottw
scottw
scottw said:This may be the thread you are talking about:
Thanx Scott... that's it.
dave
Thanks scottw and planet10, for the link and nice talk about this litle driver
i feel good about recognizing it's sound long before i read the planet10's pages
i think this driver would deserve TL box of its own, to be used as full range, as it was meant to be, but at present i have no need for such system
instead i have been putting fr drivers on the open baffle on the top of bass cabinet with success, basszila like, so even this driver ended up like that
i believe that using it primarily as midrange (from about 200 Hz) and up, limiting the bass coming out of it, and its excursion, makes midrange exceptionaly clear
tweeter is optional
thanks
ed
tweeter is optional
thanks
ed
Ping Adason, pls PM me ...
I have acquired a pair of these vintage alnico's. I'm interested to what you did with your pair.
cheers
Doug
cheers
Doug
Hi Brisso57,
sorry, I did not notice there was question, I do not get notified about the posts. This is quite an old thread.
I still do have the drivers, they are mounted on open baffle roughly 1x2ft accompanied with little tweeter. This baffle is sitting on top of closed box woofer, I believe woofer is 12". They are being used in the basement, when I work on the speaker projects. Driven by whatever is around, currently Luxman receiver.
ed
ed
adason said:Hi Brisso57,
<SNIP>
ed
What is the tweeter that you are using?
Doug
Hi Adason,
You might like to check out
http://www.diyaudio.com/forums/showthread.php?s=&postid=1639344#post1639344
post #838
cheers
Doug
post #838
cheers
Doug
hi all
that's all
I just tried this driver (the one you pictured, with a flat dust cap) in a pair of zigmahornets.
Wow! Clarity sizzle and a surprising amount of bass too.
Prior to that I tried another Sanyo FE103A variant. That one has a domed dust cap. The flat-cap variant sounds much better.
cheers
Doug
- Full Range
- little fullrange magic
