Little Big Horn
Thanks guys!
Here are some final measurements with modded FE126Es (no ENABL yet) in the Little Big Horns. The high end in the box does not rise nearly as much as on the test baffle board. I don't know why, but I'll take it. You can take the listening position measurement with a grain of salt. I can make it go from very good to very bad by moving the mic a foot. I'm measuring the room at least as much as the speakers.
Denis
So the real question...how do they sound at the listening position? Is there enough bass? Did you corner load them or just up against the wall? Have you experimented with different distances from walls?
Just got your email...guess I'll be able to find out for myself next week!
These are placed against the back wall but well away from the corners. There is probably another 5-10hz to be had on the low end if corner loaded but it's not going to happen the way the room is set up. I haven't tried any other positions yet.
Today is the first day I've had a pair to listen to. I listened to the Beatles "Love" CD and it sounded great; well balanced. I think the bass is very good but like you said, you can hear for yourself next week.
Denis
