Hi all. Just purchased a Little-Bear P1 hybrid amp - variation of Indeed/Bravo/etc. Reading some of the threads about modding, and am thinking about taking a crack at some (replacing caps, mosfets). The biggest problem I'd like to fix is the output levels. With my current phones/sources I can't get much past the channel inbalance on the volume pot before it gets too loud. Is it possible to make something along the lines of a low gain switch? Would it be as simple as just getting a different pot? I've read about changing outpu resistors, but that apparently changes the sq.
Sorry for all the questions at once, but any help would be appreciated.
Cheers
Cheers
