little 2-inch speaker surround foam vs 70% alcohol gets rubbery?
it got all wrinkly looking but once the rubbing alcohol fully evaporated the surround feels rubbery and not wrinkly looking anymore. I have another identical speaker to compare it to and it springs back instantly vs the one with soaked with rubbing alcohol then dried that takes a split second longer.
it also wont tear. I easily ripped the other one to crumbled shreds
but the one soaked in the rubbing alcohol then dried is like silicone rubber or something it stretches a little but wont tear it just deforms and slowly forms back to shape? it seems stronger even? what could cause this strange behavior? is that just how rubbing alcohol reacts with that specific speaker surround? its a really cheap 3W 4ohm 2-inch speaker from a bluetooth speaker. so they didnt cost more than a bag of chips.
what do you think about that?
Foam used in the surround is subject to solvent action of alcohol. The solvent partially melted the foam and caused the air pockets to disappear leaving behind the now parent polymer which feels smooth and rubbery because bubbles are gone?
it doesnt seem crumbly or anything though which is weird. it seems more durable than the untouched foam
And I dont do drugs. I specified specifically "rubbing" alcohol. not for consumption
Many things possible, do you make your isopropanol 70% V/V or you buy it ?
commercial product can have 1to4% of isopropanone (acetone) and other secondary product, the rest is water.
i use 99,98 minimum grade because i don't pay it and no problem on standard polymere.
if you using a grade under 99.5%, thinking acetone and avoid rubber, plastic and other polymere for safety.
Like xrk say many foam react with polaire solvant, other with appolaire....if you can't test before, don't try.
just bought in a bottle.. its just regular rubbing alcohol for cleaning wounds or other simple things
It’s probably the other ingredients that are used to denature the alcohol so you can’t drink it. Acetone would surely melt polyurethane foam. Actually, to think of it, I recall making my own polyurethane foam from a kit (poly and catalyst/foaming agent). The standard solvent recommended for cleaning up was denatured 99% ethyl alcohol.
so dont get it on any plastic or rubber or foam speaker things? what about fabric surrounds?
also could I use a few layers with drying time in between a few layers of thin rubber cement brushed gently onto a speaker surround to help make the surround last longer if its made of foam or paper? would that help make it last longer? or would it get wrinkly like the alcohol does do it?
Depends on whether or not fabric surround is doped. They generally are. The alcohol may actually melt the damaged brittle dope and reform it to a softer texture and re-seal any pinhole leaks.
is the wrinkling the material expanding or shrinking? i think its expanding maybe?
also what about the rubber cement idea? would that work or would that not work?
- Full Range
- little 2-inch speaker surround foam vs 70% alcohol gets gets rubbery?
