Perhaps this list will be more useful if the chip and discrete solutions are kept separate, as there are only a handful of discretes and hundreds of chip based dacs.
Exactly = PCM 1704 , while still love my WADIA 27 spline based interpolation sound (tube alike) than this pre/post ringing AKM/ESS and so one.
Also the soldered R/2/R stuff will get humid and poisoned over time with a guarantee of oxidation and leakage. In other words a thin laser trimmed film based substrate is hard to beet.
Hp
Zanden Model 5000
Hi JP
R2R net inside double crown TDA1541A chip, correct?
Found another maker of several ladder DAC models, some with tube-buffers, at MHDT Lab in Taiwan.
Website here: mhdtlab.com
Review of the "Stockholm 2" model here:
Mhdt Lab Stockholm V2 USB DAC
Hi JP
R2R net inside all TDA 1541 chips
According to the TDA1541 datasheet, page 5: "True 16-bit performance is achieved by each channel using three 2-bit active dividers operating on the dynamic element matching principle, in combination with a 10-bit passive current-divider, based on emitter scaling."
TDA1541 Datasheet pdf - Dual 16-bit DAC - Philips
I'm not sure why they call a circuit based on emitter scaling a passive current divider, but it sounds to me like the TDA1541 is based on scaled current sources rather than R2R networks. It might use an R-2R network to divide the current between the sources for the lower ten bits, though, depending on how they implemented that "10-bit passive current-divider, based on emitter scaling".
The PCM1704 indeed has R2R networks according to its datasheet (page 6, left column, pcm1704.pdf ): "Two DACs are combined in a complementary arrangement to produce an extremely linear output. The two DACs share a common reference, and a common R-2R ladder for bit current sources. The R-2R ladder utilizes dual balanced current segments to ensure ideal tracking under all conditions."
I just read Rudy van der Plassche's 1976 article about dynamic element matching. Apparently R-2R was a very common technique for splitting the currents in current source DACs, so chances are that Boydk and Zoran are correct and that the TDA1541 uses an R-2R network for its lower ten bits.
Hp
Not exactly understand why take the discrete R2R implemention route. To achieve even 16 bit ENOB, you need a 0.0001% resistor. Expensive but possible with integrated, laser trimmed thin film but good luck with the discrete resistors. Almost all discrete R2R DAC uses 0.01% or worse resistor that theoretically can only achieve 13 bit ENOB even if there is no noise (only non-linearity) at all.
Whats important for Audio is not absolute linearity, but good level linearity, so you don't need that precise resistors for a good discrete R-2R DAC, just use the Sign Magnitude principle (same as PCM63 and later parts)....
Better said, you need monotonicity.Whats important for Audio is not absolute linearity, but good level linearity, so you don't need that precise resistors for a good discrete R-2R DAC, just use the Sign Magnitude principle (same as PCM63 and later parts)....
- Digital Line Level
- List of all R2R DAC
