LINN PCB 018 (Speed-Checker, 300 Hz Turntable Strobe) Questions to the Circuit Diagr.
Follow questions rises up to Linn's speedchecker when looking at the circuit diagram (schematic under the first attached image):
1) What is the reason for the not present of Rx, which determine the idle current through the first transistor of the darlington LED driver ?
2) Which task has the connection at the other end of R2 (here is a not connected solder pin provided) ?
3) Why a jumper at R1 to the popsitive rail (Vdd) ?
4) From where I can get the genuine enclosure (no longer available from Linn since any years) ?
Best thanks for advices in advance.
