linn intek DC on output???
hello there
Im hoping that someone might be able to give me a hand with fixing a linn intek amp, which is outputs -40volts (same as the negative rail on power supply) DC on both channels. Iv tested the output transistors, the power supply and the prestage parts of the amp. and still no luck? im still a little confused that the fault is on both channels.
i also saw on another thread that there are people out there with some schematics to this amp? if you do could you please email them to me, would be greatly appreacated.
