"I have a Marchand which is a state-variable 4th order XO. It definetly adds a veil when in circuit. It uses a lot fewer op-amps than the posted scema. "
Uhh, the high pass output goes through two more op amps in the Marchand design, you just don't want to see them. All the noise, distortion, phase shift, etc of the four op amps in the low pass show up in the high pass when the output of the low pass is summed with the input signal. The Marchand XM16 built as a 24dB LR sounds better than the derived high pass state-variable designs.
"Could you not put a 2nd order filter on each op-amp and get away with half the active parts in the filter stages?"
Uhh, those are all second order filters already.
"My only comment is your use of 1uF and 100nF caps: what kind of tolerence are you aiming for? Sallen & Key filters are rather suseptable to variations in the RC constant caused by component tolerence.
I built something similar over the summer and used 1% polystyrene caps and 1% metal film resistors throughout."
Gee, where can I find some of those 1µF polystyrene caps?
djdan, your crossover is not configured properly.
"Click here
http://sound.westhost.com/p09_fig1a.gif
if you really want to see the old version, which is incorrect."
"This version
http://sound.westhost.com/p09_fig1b.gif
may not look all that different from the original in Figure 1, but the performance difference is very noticable. "
"For some obscure reason, I've never been able to warm
up to the sound of 24 dB/oct. It can measure great, and
I've tried it many times, but have always gotten better
sonic results with fewer poles. Go figure."
I have found that 99% of commercial units use the derived high pass with the fig1a. midrange output. These can't sound good. The best I have ever heard was a 12dB Bakgaard, followed by the 24dB LR. I have never been able to get a 12 or 18dB Butterworth to sound 'right'.
Even with a textbook perfect fig1b. LR it doesn't always sound 'right'. What the drivers are doing must be accounted for too. Many times I have had to use a 12dB Q=1 lowpass with a 18dB Butterworth high pass to get a 24dB LR transfer function.
http://patft.uspto.gov/netacgi/nph-...&p=1&u=/netahtml/srchnum.htm&r=1&f=G&l=50&s1='4031321'.WKU.&OS=PN/
Bakgaard patent, the JAES article is much more informative.
