Links to National's Audio Pages
Links to National Semiconductor audio parts:
Op Amps, Voltage References, Analog Amps
High Quality Preamps
Single Amp LME49710 http://www.national.com/pf/LM/LME49710.html
Dual Amp LM4562 OR LME49720 http://www.national.com/pf/LM/LME49720.html
Data Sheet LM4562 http://www.national.com/ds/LM/LM4562.pdf
High Voltage Version (22v rails)
Single LME49870 http://www.national.com/pf/LM/LME49870.html
Dual LME49860 http://www.national.com/pf/LM/LME49860.html
Data Sheet http://www.national.com/ds/LM/LME49860.pdf
Low Noise Voltage Reference
LM4140 http://www.national.com/pf/LM/LM4140.html
Data Sheet http://www.national.com/ds/LM/LM4140.pdf
Audio Buffer (Headphone Driver)
LME49600 http://www.national.com/pf/LM/LME49600.html?this=m5
Data Sheet http://www.national.com/ds/LM/LME49600.pdf
Preamp Application Notes
Phono Preamp Schematic and Eval Board Notes
(Joe Curcio's paper, "Keeping Up with the Demands of High Performance Audio," National App Note 1651.
http://www.national.com/an/AN/AN-1651.pdf
Overture Power Amps
Reference Page http://www.national.com/cat/index.cgi?i=i//286
LM1876 Info Page http://www.national.com/mpf/LM/LM1876.html#Datasheet
Data Sheet http://www.national.com/ds/LM/LM1876.pdfLinks to National Semiconductor audio parts:
artquake
2005-03-07 8:43 pm
Adding more to:
Dual Audio OP Amp LME49722 http://www.national.com/pf/LM/LME49722.html
Data Sheet LME 49722 http://www.national.com/ds.cgi/LM/LME49722.pdf
The LME49722 has a wide supply range of ±2.5V to ±18V. Over this supply range the LME49722 maintains excellent common-mode and power supply rejection, and low input bias current. This Audio Operational Amplifier achieves outstanding AC performance while driving complex loads with values as high as 100pF with gain value greater than 2. Directly interchangeable with LME49720, LM4562 and LME49860 for similar operating voltages.
Best regards
artQuake
