again that issue
using heavy equipped FF 51.0.1
link to exact DiyA post usually taking to top of page (same one where link is posted)
I have set "show 50 posts per page"
is it just me (FF , or some of addons I have installed) , or anyone else is having same issues ?
everything is working fine in GChrome
TIA
TIA
Your fault, as always.
Are you sure you clicked on the page # in the upper right? It's easy to forget that step even for a smart guy like you. 🙂
If you did then it might be FF related, but not sure.
example :
post #2652 in MR's thread : http://www.diyaudio.com/forums/pass-labs/201655-lamp-simple-sit-amp-54.html#post5004759
is showing two links , to exact posts in same thread ;
they're both leading me to top of that same page , where #2652 is
however !! , if I copy link (right click , copy link ) , then use paste&go FF function in address bar - it'll go to proper post
neither open link in new tab , nor open link in new window is not functioning as needed
in fact , no biggie ...... I just want to be sure that only moi is in question ....... I will manage
It seems to be the same for me ZM. I am actually having other things with the forums right now so it takes me a while just to confirm what you are saying.
