Linesource open baffel
With that Q, they would work fine IMO. With 6 drivers, you'll get about 1400 square centimeters of piston area, and at 4mm x-max, I don't see why you wouldn't cross over lower, maybe 80-100hz depending on baffle size.
Are you going to run them all up to the tweeter crossover? How will you wire them? My preference would be to run one up to the tweeter, and bring the others in at a lower frequency-a 2.5 way. That may require an odd number of drivers per side though.
That's my .02cents
Variety is the spice of life, Jason
