Linear Technologies Arduino - "Linduino" libraries
Those are neat little chips, However I am not impressed with only 10 bits worth of adjustability.
But, however it is good enough for a wide range of uses.
I did order some of the linear resistor programmable versions to mess with.
I am hoping to build a programmable generator with them with resolutions of 1Hz or 10Hz, if not 100hz or so.
Probably will lock it with a PLL to a Xtal and MCU for the divider function or something.
Just a few ideas.
Really cool devices, I also have the LTC6992 PWM chips as well.
The link to the project you mention would be nice as well.
jer 🙂
I don't see the attraction with the limited ability of the Arduino - today why not design a cape or whatever the cute name is for a BeagleBoard? the BeagleBone Black is $45 can run Linux distros with full PC ecosystem interconnect...
or even a general pupose interface like USB for use with any mini/micro/ect ATX/ITX PC?
Here's a comparison of Uno with Linduino -- you can see the header for the Linear Tech Evaluation modules, and the isolator.
