I just received a matched quad of LSK170 from the DIY Audio store.
The Linear Systems pin out diagram shows the pin out is different to the Toshiba 2SK170.
http://www.linearsystems.com/lsdata/datasheets/201110 -LSK170 Rev A17 dated 2017 08 28.pdf
If this is correct the LSK170 is not pin compatible with the Toshiba 2SK170?
I think that's an error in the datasheet you found. Here is a more recent
revision:
http://www.linearsystems.com/lsdata/datasheets/Copy_201110 -LSK170 Rev A21 dated 2019 11 13.pdf
revision:
Thanks. I was always under the impression that they were pin compatible. I hope you are correct.
Someone from LS needs to pull the incorrect data sheet.
I found the same datasheet. Dennis is correct; it's an error. Sadly, I didn't know until after bending the pins and soldering them into place on my pre-amp boards. It was the first time I had used the LS parts.
I sent a note to LS. Maybe one more couldn't hurt from you to help get it pulled.
