Linear PS with no ground pin
Hi all,
I just finished building a Pass DIY Phono preamp (actually two, one for each channel), and I'm looking at ways to power it. It requires +28-34v, ground, and -28-34v connections. I tested the boards with 6 9v batteries in series, with ground connected at the midpoint, and they work well.
So I purchased this PS: Power Supplies, Power Supply, Bench Supplies, Transformers
Unfortunately there's no ground connection on the supply, and I can't locate a schematic for it. Any ideas for using this particular supply with my project? Or is it a writeoff?
Thanks 🙂
