Linear Power Supply for SOtM tX-USB
Hello
I have a SOtM tX-USB PCI USB Card SOtM and i'm thinking to power it with a KingRex PSU (12V DC Linear Power Supply)KingRex Power Supply Unit.
I take my multimeter and check the output voltage of the Kingrex PSU and reads 13 Volts.
The SOTM TX-USB specs says
Power input
Input voltage: +12.0 V (+0.5 V,-0.5V)
Input current: 2A max on / off
4pin IDE power connector
Do you think it's safe to power the card with the Kingrex PSU.
Can be used
Hello
Power input
Power Requirements
USB power: +5 VDC
External power supply range: +7 VDC ~ 12.6 VDC
Power: 500MA>
Above this power requirements, take maximum 12.6V +5% -5% can be used.
