Can anyone tell me where I can obtain these pieces for a Linear Power 652i:
It looks as if they are .22 ohm resistors, but I was getting no hits on Mouser. Regardless, I figured I would try to fix this amp myself as part of a learning experience😀 I also wanted an excuse to run out and purchase an adjustable soldering gun😉
http://www.mouser.com/Search/Refine.aspx?N=4141191+4294619412&Keyword=0.22ohm+dale+3w&FS=True
These are 14.22mm long. Check the dimensions before ordering.
when ordering the resistors u might know this already but order some diodes also looks like one is craked in half
mike49504 said:when ordering the resistors u might know this already but order some diodes also looks like one is craked in half
I am going to test it out. The diode on the other side looks the same, but the other side is fine with regards to the resistors.
ETA: I don't know if anyone else caught this or not, but the prior owner replaced the internal 5 amp speaker fuses with 10 amp fuses. I guess that is why the resistors blew.
