Hi All...
A while back I built this Headphone OTL amp by Kurt Strain. I could never really get it to produce much base, but the midrange was buttery smooth and I liked the detail on the high end. At this point I have scrapped this amp and I don't use it, but I'd like to build a linstage with the 12AU7 and 6CG7 because I could hear some really nice sound qualities in there. I also have the hammond 269EX as well.
HeadWize - Project: An OTL Tube Headphone Amplifier by Kurt Strain
Can anyone reccomend a nice line stage or even a tube buffer circuit with these tubes that I could mate with an output stage of a DAC?
Steve
Steve
10uF won't get you much bass with a 300 ohm (or lower) headphone. Not a big fan of this design (would prefer a White Cathode Follower with a high transconductance tube like the 6922).
Check out the Akido - it's certainly popular around here and there is a combination that will work with your tubes of choice.
I increased the 10uf cap to like 30uf or more I can't remember but it didn't do much.
I'll check out the akido
Well, there's the cathode follower circuit, plate tied to around 180VDC, cathode resistor 10K, and grid biased to ground thru a half megohm resistor.
The 5963 is similar to a 12AU7.
Or similar to what I did to buffer a modified DAC using a TDA1543 (the 6111 is a low mu triode, somewhat similar to the 12AU7)
Makes sense. Into a 32Ohm load and for a corner frequency of 50Hz, you'd have needed about 100uF. About 250uF for 20Hz. The value of C1 mentioned in the Kurt Strain Headwize article seems to be based on a 600Ohm headphone impedance, and even then it's sort of skinny.I increased the 10uf cap to like 30uf or more I can't remember but it didn't do much.
for my headphone amplifier, I used 470uF output caps. The White Cathode follower was pretty good driving headphones, but I found that a Mosfet buffer does even a better job with lo-z cans.
- Tubes / Valves
- Line stage with 12AU7 and 6CG7 anyone?
