Line Doublers and 5-7 in LCD Screens
Here is the info on the screen
Model No: LNLVEDO0008
Screen size: 7.0 ( 16:9 diagonal)
Display format(dot): 1440 x 234
Input System: NTSC / PAL
Input Video Signal: Composite Video
Active Area: 154.08(H) x 87.048(V) mm
Dot Pitch: 0.107(H) x 0.372(V) mm
Outline Dimension: 166.9(W) x 101.8(H) x 12.05(D) mm
Pixel Configure: Stripe
Color: Full Color
Brightness: 350 cd/‡u
Contrast Ration: 150
View Angle: + 55�‹ (Horizontal), +15�‹/-35�‹(Vertical)
Operation Temperature: -20�‹~ + 70�‹
$179! Don't get it whatever you do. The horizontal resolution on that thing is a joke. You could buy a regular native 640x480 3:4 panel, crop off the top and bottom to make it 16:9, and you'd still have a much better resolution.
