line array with Fostex FE127E
As a first attempt, I have made a 10 liter bass reflex box
for the FE 27E, following the Fostex plan on their website.
The sound is very good: clear mid and highs, very reasonable bass (from about 70 Hz), and stunning detail, space and dynamics. Loudness is limited, however.
Now I want to bring this sound a stage further and plan to build a floorstander with three FE127E each in a line array. For the bass I intend to use my REL Q150MKII.
Do the FE127E need separate chamber of about 10 liter each (with separate ports) or is it possible to combine the volumina to 30 liters and use the same port? Or do I have to alter the port dimensions?
Any advice would be very welcome!
Ramses67
Thank you all, it seems that simply put a few FE127E's in a line array isn't automatically a good idea........
The bipole design is very interesting, as is thinking about a set of completely separate 10 liter boxes, aimed in position.
Pictures coming soon!
