I just recently noticed that in my open baffle line array, some of the drivers are putting out much more sound than others. On the bottom 8 (of 16) they get sequentially less powerfull as you go up, and the top one (of the bottom 8) must be producing half the output that the bottom one does. Does anybody have a clue what could be going on here?
If they are wired in series and the impedance curve is not identical from driver to driver, some might be louder than others. That is just my guess. As to why it goes in a certain order of decay, that baffles me (no pun intended) a bit. In parrallel, I see no reason other than they might have slightly different sensitivity. But the again where would the order in decay come from?
Hope this will help in further diagnosis of the problem.
Sébastien
Sébastien
well this is a throw in the water, but if their wired in series than the resistance will continue to get bigger as it goes up....but that makes no sense....sorry 🙁
Maybe gravity is pulling more and more electrons as it goes up
Hybrid fourdoor said:Maybe gravity is pulling more and more electrons as it goes up![]()
"As everybody knows high power amplifiers use larger electrons to achieve this high power. The bigger electrons don't start or stop as fast as normal electrons resulting in much heavier, less nimble Watts. So high power amplifiers can never have the finesse of low power amplifiers. High sensitivity speakers only work with the smaller electrons (the smallest are produced by tube amplifiers). Thus if you use a high power amplifier with sensitive speakers you need a transformer that slims down the electrons and makes them swifter. Such transformers are available from Jenny Craig Audio Inc., Phen-Fenophile Corp. and the US Nuclear Agency."
Alan Ross
PS. Don't forget to elevate the amplifiers above the speakers, so the signal can flow easier.
dave,
this is really quite simple. if you have larger electrons you need larger dia. wire. and in any case large electrons are produce bass and small electrons produce treble. just ask monster cable.
Chris,
there's not much we can do to help other than suggest you will have some trouble shooting to do, it's either
- the drivers are different
- the wiring
- something else in the signal path between the amp and drivers that you haven't mentioned
You will have to go through the signal chain and by a trial and error process of elimination. Compare the individual drivers that are different, change the wiring, put them all in series, etc.
- the wiring
How do you know that the outputs are different? Did you judge my cone motion or did you hear it only?
You didn't mention the top 8. How do they do?
- line array "bug"??
