LIMP measurements WAYYY too high
Hey all,
Hopefully this is an easy fix. I made a jig like the one here: Measuring Frequency Response Using ARTA
I'm using a 16.4 ohm resistor (well, 2 8.2 ohms in series), and I get this:
50 ohms minimum and almost 2000 ohms at Fs!!! I've adjusted the reference resistor setting up and down with no change. Is there a setting I'm missing? Any help is appreciated.
i dont use this software, but your ref R and dut should form a voltage divider, then the software measures the v arcoss you dut and calcs imp.
Check your connections etc, software setup etc.
Use a 10R etc instead of a speaker for now, when everything is ok it should measure 10R at 0deg across your set freq range. Then you can test a driver knowing your setp is ok.
