I have an application which requires that an audio signal be limited to 2mVpp. After 2mV level, I want the signal to clip. Under 2mV, no clip. I have an opamp in the circuit, and can use this opamp as part of the clipping circuit. When the signal is below 2mV, the clipper circuit must not interact in any way with the signal. I'm looking at a diode clipper, etc.. Does anyone have an opinion on the "best way" to do this?
What is the source and destination for this 2 mV signal. The source and destination impedance will come into play.
