• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
Limited offer of Aleph30 PCB boards
Dear PD, your work looks more than professional! :nod:
The boards are very well made. Thank You.
Just a curiosity: they look different colour in traces... maybe different run?
BTW, I am waiting for your next Pass-project boards (AX??) 😉
Cheers
Peppe
Yes, it is different runt, that's why the color is slightly different as well.
As a matter of fact, I'm working on another Pass project. It is Ono, but only the MM version. This layout took quite a long to complete, but I really like it.
Peter Daniel said:
As a matter of fact, I'm working on another Pass project. It is Ono...
ONO! :happy2:
It looks perfect to me! :happy1:
I can wait... I am still working on others projects... 😉
The picture looks very small, I love your way to make very compact PCBs to have the shortest possible signal path!
Maybe this question will arrive from someone: why not MC input?
The output will be balanced... of course(?)
Cheers
Peppe
If you click on a picture it becomes bigger.
No MC as I'm using step up transformers and don't need MC section.
No balanced output as I used line transformers and they do conversion better.
taccodude said:
Hi, Peter did You get the Money?
Was it mail or paypal?
Cheers
Peppe
Sorry to pester you, but I also very much would appreciate a pair of equally professionally manufactured Aleph-X (courtesy of np/gray vs hifizen/grataku) boards as well. Any plans along that path?
Hilbert
Actually, I have some stok of hifizen/grataku boards and if you want build Aleph X amp you can use that board for front end and A30 boards for outputs (if you want more than 2 devices per side).
I'm building such X amp (4 devices per side), although my front end will be p2p wired. If you need hifizen/grataku AX board, e-mail me.
You don't really need boards to build those amps 😉
Absolutely brilliant!
I stick to the middle and go for AX boards, but no 30's.
You've got mail.
Hilbert
Sorry for my lack of knowledge on the Aleph 30, but the boards are described as 2 channel boards. When i look closely at the silkscreen on the board it looks like it's only one channel.
And on BrianDonegan's pic it seems he has one board per side. Can someone please explain to me? (im still going to build an Aleph 30 anyway so i can learn these thing's 😉 )
Thanks for your time an patience,
Joel
