Limitation on floating PS/circuit
What are the limiting factors for floating a particular power supply or circuit above its return potential? Is it just the transformer and wire insulation ratings? I imagine that device ratings should not be a problem, since the difference in potentials all remain the same when floated?
electrostatic shields increase C to each winding they're in between so the load effect would actually be worse
the easy way to minimumize pri-sec C is using split bobbin EI power transformers
a standard construction is "universal/international" double/reinforced insulated - for domestic line V these have to pass a 4KV HiPot test
they are actually better than many "traditional" tube power supply transformers on capacitance, insulation V rating
for even more fun you could float a single polarity supply with anti-phase driven H-bridge output
