Lilliput dimensions (stripped)
Does anyone have the dimensions fo the actually stripped LCD panel for the Lilliput 7" VGA? Couldn't find it in the search tool.
As a related question, does anyone know if getting the touchscreen version would cause any problems in usability? Doesn't it just come off?
Thanks!
Thanks!
I had estimated about 155 x 87 but used some assumptions that weren't solid. Thanks for the info.
I'm looking at useing the 250 Metal Hallide (is the extra refector good?) with a 220 mm rear fresnell and a 330 mm front fresnell into the 80mm triplet from DIYProector Company.
Does a lens expect the light to converge to a point in the center from FL distance? Or should it be closer to account for the width of the recieving lens? (need to break out a book on optics)
