I aquired a Lightware L-1020 projector
http://www.projectorcentral.com/Lightware-L-1020.htm
It powers up fine, and the initial image is perfect, but then it will start to shake a bit, then distort, then go back to perfect. The source is fine, I confirmed, it is all the projector. There is no variation; it does the same thing, rather than giving it a serial or video input.
Bulb is good.
Any ideas what may be the culprit?
Bulb is good.
Did you ever get any comments on your projector problem?
Today the image on my Lightware L-1020 went bad. It's pixelated, like when you zoom way in on a bitmap. The reset doesn't fix it. Anyone know what's wrong?
