see http://www.ushio.com/files/UHI-SE SpecSheet 1101.pdf these bulbs are much much smaller, both in wattage (up to 150) and size. they are UV protected, G12 base, "axial arc" (smaller more point-like source), the UHI-S150DM/A is 4200K/13000 lumens/10000 hours and uses m102 ballast.
only source i've been able to find is http://www.purelandsupply.com/item.jhtml?UCIDs=714694|1108137&PRID=1160766 - $52.
only problem is i am unable to find a G12 socket for mounting these 🙁
I actually use similar lamp by philips ($56) the dimensions are pretty much the same and so as the brighness. I had hard time finding the socket untill I discovered a local place where they have it for $9 each and bought G12 and G9.5 for my other lamp.
The first link has the home page address describing the socket and the second link has the contact info. I bought it from one of their local distributor in San Francisco.
http://www.buhl-ind.com/
Sorry the second link is a pdf file but click on the ordering info to get the addresses of local distributor near you.
I now have the lamp, ballast, socket, and bought a nice ellipsoidal reflector to go with the lamp dimension. I am now working on a way to connect the lamp&socket assembly with the reflector so that the lamp is located in the focus point of the reflector..its little tricky since I have to come up with some mechanism where I can slide the lamp back and forth to get it right in place. I will post few pictures on the forum later but here is some pics from my other thread
http://www.diyaudio.com/forums/showthread.php?s=&threadid=7864&perpage=15&pagenumber=4
Also, if you are going to use ellipsoidal reflector, we have pretty good discussion there on that.
rajkumar said:I actually use similar lamp by philips ($56) the dimensions are pretty much the same and so as the brighness. I had hard time finding the socket untill I discovered a local place where they have it for $9 each and bought G12 and G9.5 for my other lamp.
what details on this philips lamp? is it also UV protected like the ushio lamp?
rajkumar said:
"Enclosed Luminaires Only"
i assume this means the lamp puts out UV - i hope your setup is shielded.
My projector is not finished yet but I have an elliptical reflector which covers the lamp and the focus point where light will gather will have a condenser lense so all light has to go through the lens which (as far as I know) will filter UV.
I might use a UV filter film/glass between my LCD and the lamp.
