yhw, you have quitre a setup. can you give us detailed information on your light setup, with pictures and diagrams if possible. I know i'm asking a lot of you, but any input on the lighting and optics used in the lighting would help a ton. Thanks for sharing.
MODERATORS..
PLEASE DELETE THIS
i misposted and realized, but made a mistake while trying to delete, and cannot. thx.
PLEASE DELETE THIS
Sweetrobot said:yhw, you have quitre a setup. can you give us detailed information on your light setup, with pictures and diagrams if possible. I know i'm asking a lot of you, but any input on the lighting and optics used in the lighting would help a ton. Thanks for sharing.
with this picture
1, enough light :250W,300W,400W,575W high voltage Metal Halide Lamp, but not 24v,36,Halide lamp,almost all OHPs need to change Lamp.
2,dot Light source, the Light source must like a small, round bead.it's diameternot not more than 2CM. maybe it has a glass cap, if the glass cap like a cannulation, ok ,but if the glass cap like a ball,dont use it ,
3,viewfinder:like half ball, lnes😱ne face protruding one face concave
ywh,
where did you find that double ended lamp? Looks exactly like the lamp in my sharp lcd projector. What is it's rating? 250W-275W? How much did it cost?
thanks,
ap0the0sis
thanks,
ap0the0sis
ap0the0sis said:ywh,
thanks,
ap0the0sis
Canton,a shop of special type lamp
300w.
about us$ 20
that is a small shop, has no link.ap0the0sis said:ywh,
could you link me to their site?
Thanks,
ap0the0sis
it was difficult for me to understand your last poin, regarding the viewfinder over the bulb.
can you give us a picture while it is set up?
thx
thx
check out this diagram- http://www.hpk.co.jp/Eng/products/etd/metahae/metahae.htm
i think it shows pretty well that there must be a condensing component built right into the bulb glass, did u mean that when you were referring to the viewfinder lens in your answer yhw? to use a small lens to condense the emitted light?
http://www.hpk.co.jp/Eng/products/etd/pdf/L5431_TLSO1011E03.pdf - this is the bulb for a projector- it does really resemble yours! i need to find out how to get a hhold of one of these. if it comes down to it, i'll have to send money to china so you can get me one.
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- Light source
