light out the blow hole
I work with "High End" lights for a living... if you check out their site (www.highend.com) - look up the layout for their new Trackspot 2 units.
They simply use two plates of steel mounted in a pyramid shape to the inside of the fan. Works like a charm. Their other units use blower type fans. You get the same effect with blower fans but because they move less air you'll need a bunch of them. The pyramid idea would be best.
-John
